[SOLVED] tips for beginners (0 viewing)
TOPIC: [SOLVED] tips for beginners
#1363
gaetano
[SOLVED] tips for beginners Karma: 0
hello,
before installing jsitemap i use a sitemap in webmaster tool google.
1) i must delete the sitemap in webmaster google ?
2) i must add something for example a new path sitemap of jsitemap in webmaster tool ?
about jreview
1) i read something for jreview integration but i don't understand how change the path for images, infact jreview use the path media/images how can i change setting jsitemap for jreview?
thank you
#1364
Re:tips for beginners Karma: 84
Hello gaetano,
you can delete the old link to sitemap in your Webmasters tools of course, submitting the new one of JSitemap for the XML or images sitemap that you find in the component dashboard.
About JReviews, to include images stored in the media folder you can remove the exclude filter for the 'media' in the data source 'Content' as shown in the attached picture.
#1365
gaetano
Re:tips for beginners Karma: 0
thank you,
for jreview:
i must create a custom data source and delete "media" as shown in the attached picture.
but i must add other parameters you can see if they are correct ?
#1366
An additional data source is not needed for JReviews.
JReviews uses the same links generated by Joomla for articles so it's supported by default by JSitemap using the native data source of type 'content'
The 'media' folder can be excluded in the 'content' data source
#1367
gaetano
ok now understand,
but I would avoid the index folder images , how can I do
#1368
Using exclude filters you can easily choose folders or paths to use for images,
Removing the 'media' all images under media/image.png will be included
Adding a more exclusion 'index' following comma separated, all images with 'index' will be excluded
