Re:tips for beginners (1 viewing)
TOPIC: Re:tips for beginners
#1375
Re:tips for beginners Karma: 84
Hello gaetano,
if you need to exclude images crawled from menu links, the easiest way is exclude various menu data sources from the images sitemap, as shown below.
#1376
gaetano
Re:tips for beginners Karma: 0
i try it but the menu are still index and jreview don't index
#1377
Try to post links to images and to your site, otherwise it's difficult to understand what images need to be excluded
#1378
gaetano
http://www.visitasicilia.com/modules/mod_gtranslate/tmpl/lang/blank.png http://www.visitasicilia.com/images/nuove_icone/guida vacanze sicilia mobile.png http://www.visitasicilia.com/images/nuove_icone/guida vacanze sicilia.png
and i found an error when i click on "analyze sitemap links" i get a blank page
#1379
Add more exclusions filters comma separated to exclude those images,
see below screenshot, for example 'translate' and 'icone'
#1380
The blank page could hide a php error on server, try to enable the component debug before start the Links Analyzer and eventually even the error reporting in Joomla global config
