XML processing fault (1 viewing)
TOPIC: XML processing fault
#1799
Boomgaarden Klaus
XML processing fault Karma: 0
I just installed the latest release of JSitemap PRO 3.2. on Joomla! 3.4.1
When I want to let me show the different XML sitemaps I get the following error:
XML-Verarbeitungsfehler: "Junk" nach Dokument-Element
Adresse: http://agentur-komet.de/index.php?option=com_jmap&view=sitemap&format=xml
Zeile Nr. 2, Spalte 1:<b>Warning</b>: ini_set(): The script tried the 'memory_limit' to provide infinitely in <b>/var/www/virtual/agentur-komet.de/htdocs/components/com_jmap/jmap.php</b> on line <b>14</b><br />
Best Regards
Klaus
#1800
Re:XML processing fault Karma: 79
Hello Klaus,
it's related to server settings, memory management by scripts is not allowed in this case.
You should switch in the component settings the resource management from 'component mode' to 'server mode' see the image below.
Also ensure that the PHP debug option is not enabled and error reporting from Joomla in the global config is not active.
#1801
Boomgaarden Klaus
Re:XML processing fault Karma: 0
Hello John,
thank you, now it works fine!
One question to google webmastertools: I get warnings because "sitemap contains URLs, which are blocked from the "robots.txt"-file."
Klaus
#1802
That's great Klaus,
about the google webmasters it's because the robots.txt is disallowing images included in the 'cache' folder.
You need to add an exclusion filters for the images sitemap in all data sources published for the 'cache' path, see below:
#1803
Boomgaarden Klaus
Hello John,
ok, but unfortunately I can`t find any configuration field like your attachment in the control Panel.
Where can i find this line?
Klaus
#1804
Hello Klaus,
not in the control panel, but in the edit screen of data source records.
Clicking on the data sources name you will open all the settings screen.
