Re:JSitemap Cache issue (1 viewing)
TOPIC: Re:JSitemap Cache issue
#3147
pistipixel
Re:JSitemap Cache issue Karma: 0
here are my caching setting
#3148
Re:JSitemap Cache issue Karma: 84
Can you please explain me exactly the problem? The cache settings are the default ones and are ok.
The XML sitemap format in your previous screenshot is marked as green, completed and ok.
What's exactly the problem please? Other formats don't complete?
#3149
pistipixel
all other sitemaps can´t be precached. The popup runs very long, then its closed an nothing is happened.
session is set to 120, so there can´t be a timeout
#3150
The problem could make sense for the images sitemap that takes very long time compared to the normal XML and normally should not exceed few hundreds of links involving the images crawler.
But all other sitemap formats like the 'mobile' work exactly as the default 'XML' that indeed completes. Try to start a precaching for the mobile and report if it completes.
#3151
pistipixel
mobile site is done, now the other is running
