sitemap.xml not being recognised by SEO checkers (1 viewing)
TOPIC: sitemap.xml not being recognised by SEO checkers
#3667
Richard Wootton
sitemap.xml not being recognised by SEO checkers Karma: 0
Hi
I've got sh404SEF and am trying to get the mydomainname/sitemap.xml file to be recognised by such as SEO Quake and SEOptimer but they keep reporting the file does not exist. I have read through the documentation about adding
RewriteRule ^sitemap\.xml$ index.php?option=com_jmap&view=sitemap&format=xml [L]
to the .htaccess file
and seen the post below
http://storejextensions.org/forum/view/10-jsitemap/2395-solved-sitemap-xml.html
but nothing seams to allow the url http://jkcourierandhaulage.co.uk/sitemap.xml to be recognised.
I have created http://jkcourierandhaulage.co.uk/sitemap.xml by changing the sh404SEF url link /sitemap to /sitemap.xml and adding the rule into .htaccess so I have successfully created the url redirection below
If you go to
you get
Which shows the classic xml structure as required.
Have I done this correctly?
Is there something else I need to do to get the SEO checkers to recognise sitemap.xml?
Cheers
#3668
Re:sitemap.xml not being recognised by SEO checkers Karma: 84
Hi Richard,
this is the answer: http://storejextensions.org/faq/why-online-seo-stats-services-report-missing-sitemap.html
Seo checkers are dumb and only able to detect physical files on the server and nothing else. You can place a static sitemap.xml file at the root of your site if this makes you happiest but it's not required at all.
The only thing that is required is that the sitemap entry is present in the robots.txt
Cheers!
#3671
Richard Wootton
Re:sitemap.xml not being recognised by SEO checkers Karma: 0
Thanks John
Does this mean I can/should reverse the sh404SEF url change and remove the .htaccess entry?
I gather submitting the sitemaps to the url is therefore also needed even if I have submitted them already to GWT
Cheers
Rich
#3673
Hi Richard,
well if you did it just use it for GWT that's ok.
With the htaccess entry the link:
is simply an alias of the normal link:
http://jkcourierandhaulage.co.uk/index.php?option=com_jmap&view=sitemap&format=xml
Submitting the alias http://jkcourierandhaulage.co.uk/sitemap.xml
to GWT is ok as well.
