Re:sitemap.xml not being recognised by SEO checkers (1 viewing)
TOPIC: Re:sitemap.xml not being recognised by SEO checkers
#3668
Re:sitemap.xml not being recognised by SEO checkers Karma: 84
Hi Richard,
this is the answer: http://storejextensions.org/faq/why-online-seo-stats-services-report-missing-sitemap.html
Seo checkers are dumb and only able to detect physical files on the server and nothing else. You can place a static sitemap.xml file at the root of your site if this makes you happiest but it's not required at all.
The only thing that is required is that the sitemap entry is present in the robots.txt
Cheers!
