Re:sitemap.xml not being recognised by SEO checkers (1 viewing)
TOPIC: Re:sitemap.xml not being recognised by SEO checkers
#3673
Re:sitemap.xml not being recognised by SEO checkers Karma: 84
Hi Richard,
well if you did it just use it for GWT that's ok.
With the htaccess entry the link:
http://jkcourierandhaulage.co.uk/sitemap.xml
is simply an alias of the normal link:
http://jkcourierandhaulage.co.uk/index.php?option=com_jmap&view=sitemap&format=xml
Submitting the alias http://jkcourierandhaulage.co.uk/sitemap.xml
to GWT is ok as well.
