Re:XML sitemap display (1 viewing)
TOPIC: Re:XML sitemap display
#5584
Re:XML sitemap display Karma: 84
You have confused me too
Normally you should use a footer menu and link with a menu item the HTML sitemap not the XML sitemap... what you are doing is a bit weird.
The footer should have this link:
https://wightshops.com/index.php?option=com_jmap&view=sitemap
to show an end user sitemap tree.
XML is only for search engines.
XML sitemap display
Wightsynergy
thread linkthread link Re:XML sitemap display
thread linkthread linkthread link Re:XML sitemap display
Wightsynergy
thread linkthread linkthread linkthread link Re:XML sitemap display
thread linkthread linkthread linkthread linkthread link Re:XML sitemap display
Wightsynergy
thread linkthread linkthread linkthread linkthread linkthread link Re:XML sitemap display
thread linkthread linkthread linkthread linkthread linkthread linkthread link Re:XML sitemap display
Wightsynergy
