Re:Change module order (1 viewing)
TOPIC: Re:Change module order
#6905
Re:Change module order Karma: 84
it depends on the module positions associations. The position-7 by default is mapped to the 'responsivizer_left' that is before main content. You can change the associations to 'responsivizer_right' or below positions. The positions mapping of Responsivizer is visible below.
The menu module must have an active instance for example assigned to the position 'responsivizer_menu_top' or 'responsivizer_menu'. Refer to the PDF docs at the paragraph 'Mobile menu management' for more info.
Change module order
LN Webdesign
thread linkthread link Re:Change module order
LN Webdesign
LN Webdesign
thread linkthread linkthread link Re:Change module order
thread linkthread linkthread linkthread link Re:Change module order
LN Webdesign
thread linkthread linkthread linkthread linkthread link Re:Change module order
LN Webdesign
