RSS feed not showing Images (1 viewing)
TOPIC: RSS feed not showing Images
#3069
CW WebworX
RSS feed not showing Images Karma: 1
I am trying to set up the RSS feed with JsitemapPro. All the images show a broken icon where the image should be.
How do I show images with the RSS feed?
I then send it to google feedburner.
Thanks.
See sample screenshot attached.
#3070
Re:RSS feed not showing Images Karma: 84
it looks that the problem is due to the link used for images being relative instead of absolute.
If the link for images is relative and doesn't include the full domain URL pointing to your site, images won't work when included in an external document such a feed.
Check if that's the case and correct the link for images including the full address.
#3071
CW WebworX
Re:RSS feed not showing Images Karma: 1
Thanks. How do I check and change that? RSS images do show up if I use the joomla syndication link instead of Jsitemap Pro's rss link. .
Cheers!
#3072
Yes it looks that that's the problem, instead of changing links to absolute, i will send you an updated package to do this automatically.
#3073
CW WebworX
Thanks. Email was sent.
Cheers!
QUOTE:
Yes it looks that that's the problem, instead of changing links to absolute i will send you an updated package to do this automatically.
#3074
CW WebworX
Hi John, Got your email. New version works perfect!! Thank you!
Cheers!
CW WebworX wrote:
[quote]Hi John,
Cheers!
