Re:RSS feed not showing Images (1 viewing)
TOPIC: Re:RSS feed not showing Images
#3097
CW WebworX
Re:RSS feed not showing Images Karma: 1
Problem with RSS. It updates the rss feed but it adds everything up to two months old. It adds the latest blog postings, but then adds everything else that is within two months. What we need is for the rss feed to only add newest articles since last update. Is this possible with this extension?
#3099
Re:RSS feed not showing Images Karma: 84
Hi again,
if i'm correct i configure it in your Joomla backend to include articles in the latest 2 months.
it can be changed to a minimum value of 1 month from the dropdown that you see in the data source. As for now there are no other option for RSS format, eventually i can consider new parameters for the next release.
#3101
CW WebworX
Yes you did. But if I change it to 1 month, it also changes the html sitemap on front end to same.
What I need is for the RSS to update only new articles added since last update. In most cases that is daily.
Thanks!
John Dagelmore wrote:
QUOTE:
Hi again,
#3102
Ok, i logged to your site and splitted to a new different data source for RSS feed 'RSS Sitemap Listing' limiting to 1 month.
I will add a new parameter in the next release to limit it to 1 or 2 days.
Cheers!
#3110
CW WebworX
Thanks John!! Great Support!
Maybe you can add a feature that can check publish date of articles and flag only new articles to be included. Joomla is missing a good RSS feed aggregator. This one is excellent and I look forward to the next version. If you need to test it let me know.
Cheers!
Cheers!
#3111
Thanks Tony!
Yes i think that if you can be involved to the testing phase this wold be awesome! The first step would be adding a parameter to include feeds daily. I will save your email address and contact you at the right time
Cheers!
